991.2 Oil Leak - help locating
so my 991.2 Cup developed a smallish oil leak at the track yesterday. I say small based on the fact that the % on the ICD didn't drop a huge amount (maybe about 10% over the course of the day) and I had a few drips in the paddock.
However, once I got the underbody apart I could tell there was quite a bit of oil but couldn't pin point where it's coming from. It's mostly on the passenger side and in front of the engine, seems to be around and below the tranny. I suppose it could be tranny fluid but seems more like engine oil. Pics attached. Any likely culprit in this area? Anywhere else I should look? I plan to run the engine and see if I can see any drips coming out but short of that I'm looking for advice. Thx.
I suspect you're right. A bit more information, I changed the oil about 3 weeks ago and had a test sent off to Blackstone labs that showed no coolant in it. So does that preclude ahead gasket leak?
Does that leave the oil cooler or transmission cooler as the potential failure point? Is there a way to determine which?
The location sounds like the oil tank, but that wouldn’t make sense for oil/coolant mix.
Regardless, the cooling system will need to be flushed once fixed. I assume this really needs to be done at a shop?
