black covering one manifold - other white? porsche 991.1 cup
Hello
i dismanteld my rsr exhaust and on cylinder 6 there are black, wet coatings. the oher cylinder looks good?
i checked also the spark pluges, the one from cylindrr 6 are dark brown, the orhers are light brown.
what could be wrong with cylinder nunber 6.
here are some pics.
bye
Wolfgang
right on the pic is wet and shining, the left looks dry
manifold frim cylinder number 6 is dark
spark plug is darker than the others
here are some pics.
bye
Wolfgang
How much time on the engine?
Which RSR is it?
Where are you located?
Since only one cylinder is oiling, could be an issue with the oil control rings in that hole, damage to the cylinder, a valve guide issue, or even a valve seal. Are you due for an engine refresh?
Which RSR is it?
How much time on the engine?[/QUOTE
not more than 40 hours, dont know now the real hours, but the engine was revised bye Mamorow 2018 and 2019 reinstalled
Which RSR is it?[/QUOTE
only the exhaust is from an 997 year 2012 or so, the engine is 991.1 3.8 standard cup
Where are you located?[/QUOTE
Austria
Austria
is there a possibility to see a failure in Racecon? could be a bad injector the problem? or a bad spark plug or ignition coil?
