Are the centers previously used? I ask because I just had to replace one with several bolt holes that wouldn't accept proper torque.Thanks.
They are previously used. Which should never be a problem for this unless the threads had been stripped from over-torqueing. 155 inch-lbs is the correct torque, which is only about 13 ft-lbs. This is a very light load.
