997.2 Cup Car Spec Wheels
Correct. I'll note that 👍
I think I've gathered the information needed. Was up all night fooling around on Google.
Found out the 0288170 centers are Cup centers drilled to 5 lug. Not sure if those are the same as powdrhounds set.
Cup Spec:
Front: 1.5 / 8 ET + 36.5
Rear: 3.0 / 9.0 ET + 30.0
My street setup
Front: 2.5 / 6.5 ET + 25?
Rear: 3.0 / 7.0 ET + 31?
Not sure what the exact offsets would be after the changes.
Update: I decided to go with a set of Fikse Wheels. I'll be running 18x10 +38 and 18x12.5 +47. That will be with 2" outers up front and 3" outers out back. I've gathered some tire size combos based on stock specs. Most likely going to be running NT01's.
PLEASE ADVISE ON BEST TIRE COMBO
Tire Sizes:
[ - fr tire & rr tire - tire height % diff(tire heights)]
-245/40/18 & 305/35/18 - 2.7%(25.7/26.4)
-255/40/18 & 315/35/18 - 2.7%(26/26.7)
-265/35/18 & 315/30/18 - 0.4%(25.3/25.4)
-265/35/18 & 335/30/18 - 2.4%(25.3/25.9)
-265/40/18 & 295/40/18 - 3.8%(26.3/27.3)
-255/40/18 & 325/35/18 - 3.8%(26/27)
___________________________
OEM C4 tire:
- 235/40/18 & 295/35/18 - 2.8%(25.4/26.1)
OEM Turbo/GTS tire:
- 235/35/19 & 305/30/19 - 2.7%(25.5/26.2)
OEM C2 tire:
- 235/40/18 & 265/40/18 - 3.5%(25.4/26.3)
OEM gt2/3rs tire:
- 245/35/19 & 325/30/19 - 3.5%(25.8/26.7)
Tire Sizes:
OEM C4 tire:
OEM Turbo/GTS tire:
OEM C2 tire:
OEM gt2/3rs tire:
