Bbs Motorsport 997 cup wheel centers fs 997$ bps
lordpantsington (01-01-2020)
I'd still like to see a photo/measurement like the one above with a 0229052 center. But I doubt they are the same.
In the front both the 996.2 and 997.1 run 1" outer, 8" inner. Offset for the 6 is 46mm, 7 is 43mm. In 2006 the gasket ring also got a new 997 part number, but I doubt it changed thickness and moved the centerline.
you’re lost. A set non modified 997.1 wheels, yes. But we’re talking only about the 997.1 centers which using the same inner and outer barrels as a 996.2, will only bring the wheels 3 to 4 mm outwards.
The following 2 users liked this post by ghhally:
lordpantsington (01-04-2020),
spiller (01-05-2020)
Widetrack, get that extra. 25 inch track width to dominate your competition...
696$ for the pair BPS confirmed will work fine on 996 using your existing wheel halves. Also stronger than earlier centers...
