Question: Plumbing and Use of Sobek Water Pick
I am curious to know how the plumbing on a 996 Cup works for the Sobek Water Flush and Water Pick. My car does NOT have the quick disconnect couplings for the Sobek Water system. I use the AirLift vacuum system to purge the cooling system and then fill it.
- I presume that the same couplings for the Water Fill system would be used?
- Is it simply a matter of disconnecting the Quick Connect coupler and plugging the Water Pick in?
- How does one govern the amount of coolant that is injected into the system?
- Is the injected coolant flowing into the expansion tank or into the system?
- Are the quick disconnect components readily available in both plastic/PVC and metal connectors? If so, care to mention sources?
Would appreciate learning more.Thanks,Toby
