Trailering a cup
Trailering a cup
I'm in process of acquiring my first cup, a 997. I currently have an open trailer, but will likely get an enclosed at some point down the line. Until then, whats the best way to secure the car for transport? I had tie-down rings bolted to the chassis of my street-car-turned-race car, but I'm not sure that's feasible with the cup. Appreciate any insight.
Centerlock tie down nuts, they replace the regular center lock nuts and have loops on them that make it much easier. You'll find with the Cup, you cant get under the car the trailer to tie to the chassis.
Tie down rings as stated above work great. You can also use a strap through the wheel (mac's sells these). Both work well. If you bought a gen 1 and need the rings PM me. I think I have a set somewhere.
Basic Sponsor
We have the travel rings for sale that are mentioned above.
We cross over the tie downs in the rear in an x pattern, but in the front we have E-Track on the outside edge of the trailer so that the straps go out, not in, so no damage to the front bumper when towing.
Ed
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
Ed
Ed
we use the rings in a tpd 24 trailer.
I have installed L-Track on the outer sides of the box and just attach there.
never had issues towing from the bay area to Thill, Sears, and Laguna.
I figure if those rings can hold the car in a plane they are good enough for the road
I strap my cup down over the top of the tires. Everyone told me I wouldn't be able to get the straps over the rear tires, but so far I haven't been stranded. This is a superior method to transport rings or going through the wheel IMO as there is almost zero chance of your wheel alignment moving if you go over the tires. Not to mention the car doesn't move one bit. I have a punched floor on my open trailer to allow this method.
Basic Sponsor
Ed
Ken -
FWIW I use the Rennline tie downs for the front......provides an easy cross and easy access in an enclosed trailer. And I use axle straps around the rear subframe for the rears. Also provides an easy cross and everything stays nicely planted.
Glad to hear you're moving forward.
