gear poti 991 cup?
recently i checked the voltage in the active life display in my car - 6th gear engaged the value should be 4.5 volt (value from the manuel for my 2013 modell)
i have 4.52volt - is the value ok or should i adjust the poti?
perhaps someone have also the values from. the other gears - if this is important to check
bye
bye
