Porsche Cup Cars
Sponsored by: Race Cars For You
My 996 cup is SLOW - speedo accuracy?
Old 05-27-2018 | 09:32 AM
spiller's Avatar
spiller
Originally Posted by amso3
This is what Porsche showed in the 03 documentation. The tires are just about the same diameter so that should not be the issue.
Right, thanks for the info and very interesting. I’ll be getting hold of the motec gear so I can check my data in future.
Video from the day
Old 05-27-2018 | 11:24 AM
claykos's Avatar
claykos
If you have stock 2003 cup gears, 5th is a 32/35 (1.094) ratio, and a 8/32 (4.0) ring and pinion. With the standard 680 tire, 8000 rpm (stock redline) in 5th is about 146 mph, 7500 is 136. My guess is your 135 is accurate from watching the video - seems like around 7500 rpm or less.
Old 06-01-2018 | 04:09 PM
Vince964T's Avatar
Vince964T
I have the same on mine, a 2003. Speedo crawls past 180kph.
On a fast track I am at 220 entering the braking zone where my previous 6cup (an 05) had 240 reading on the VBox...
As my toplaps were 1,5sec faster with the "slower" car I was not to worried.
But just for peace of mind I checked 2 videos next to each others and the 2 cars perform with little difference.
I also ran a GPS in the slower car and the GPS speed difference between the 2 cars was only 2 to 4 kph.
I run more wing in the 2003...Standard Michelin N2 tyre sizes on both cars.
Just strange !
Old 06-02-2018 | 10:25 PM
spiller's Avatar
spiller
Just strange !
So the speedo in your 05 was more accurate than the 03...very odd! I was only going by the digital speedo on the day but should check the analogue read out next time to see if it coincides. You’d think it would. The other 996 cup at the track with me was shifting slightly earlier with his 7300 rev limit so I’m not too worried. I’m ordering the motec gear so I can access my data in future.
Old 06-03-2018 | 03:24 PM
Vince964T's Avatar
Vince964T
I can't say I remember regarding the 05 cup, I was not looking at the speedo much. But I have the onboard data/footage from the racelogic system the car had.
Quick Reply: My 996 cup is SLOW - speedo accuracy?
