SLM Porsche Motorsport base
Hi guys!!
Can anyone give me the Porsche code for this base that holds SLM on top of it??
I want to order it.
I do not care about the switch or the warning light it has on it.
Thanks in advance for any relative info.
I want to order it.
Unfortunately, with everything is how Porsche sells it.
I tried to buy just the base a couple of months ago.
The price for the full assembly is 997.641.053.90 $1220
Ed
Ed
Tried sourcing this back in the day. Ridic expensive as others said. I ended up velcroing the SLM to the top of the dash and it works fine for me... the master caution light you can program to go elsewhere (incl. the SLM) and the dimmer button rarely gets used unless you do night racing...
I just did this on my car. When I bought the car, the SLM was mounted above the Motec display in a cutout in the dash panel. I wanted it up top more in my line of sight. I could have gone the just attach the SLM to the top of the dash deal, but turns out I needed the mount. When I had the ABS system installed, I needed a place for the ABS caution light. My center switch panel was already pretty full and that SLM mount comes with an extra hole that turned out to be a perfect place to put the ABS light.
Like everyone says, the mount is a bit overpriced, kind of like the $400 decal that goes on the steering wheel. But having just finished a pretty comprehensive refresh on my car, I'm getting used (or maybe it's numb) to the prices.
