Motec SLM pigtail needed
I am looking for the opposing side of the SLM shift light connector (with pigtail wires) that I can wire into the dash for my 2008.
Does anyone make one or can make one up for me.
Ed
Ed
Hi Ed
I can probably make a harness. Is the SLM raw ended now? Do you have a wiring diagram with connection instructions? I have to tool and pins to make the connections to your dash
Thanks Jerry, No, the SLM has the connector on it that it came with, but I am completely unable to successfully make the making connector that will work.
Ed
Ed
Ed
I assume your SLM came with a 4 pin DTM connector. Did it come with the mating connector, raw parts? If so I can send you two wires for CAN + and CAN - with the proper pins to connect to the ADL 2, along with the insertion tool. For power and ground, you'll probably need to splice on to the wires already in terminals 7 and 8. You will need to connect these wires to your mating connector. If you don't have that I might have one.
Yes, I can send you everything I have including the SLM. I can splice into the wires coming from the Motec, so no need to have the pins on the motec side, just a raw pigtail.
Unless I can send you that end of the Motec harness too and you can add those pins for me too.
Ed
Ed
Ed
Do Not send the Motec car harness. I will put pins on the CAN wires, you can snip them off if you want to splice to other CAN wires. I think you have my address, I am in Florida these days
Jerry
Jerry
Jerry's always been super helpful and was instrumental in getting my 997 off the ground. OP you're in good hands.
