Can I work on a Cayman?
check out gregsmithequipment.com for a 6 thousand pound mid-rise lift....they are in del. and if you pick-up and pay cash you can make some good deals with them. You may need to use planks to drive up on [2x12] the po can be low. There are many low buck ones.....do not cheap out
Wow, bobkid, that is nice and a great use of space. Unfortunately my F250 won't fit under the Cayman with my ceiling height! Do you mind me asking how much that lift ran you? I definitely need to get something because I just closed the deal on the new to me cayman yesterday. Hopefully pick it up Monday.
http://www.gregsmithequipment.com/At...rage-Pro-8-000
A lift would be great, but is by no means needed for 95% of the work you would do on a cayman... A good low-clearance high lift jack combined with four quality Esco jack stands will put the car at the right height for most service, and still allow you to work under the car (albeit lying down) for the rest. Super stable as well.
This is my Turbo on that setup, but I did plenty of work to my previous Cayman on the same stands... Some things are easier on a 911, some things are easier on a Cayman, but both are great cars to work on yourself. I enjoy working on these far more than any other car I've ever wrenched on. Not that I haven't cursed a time or two on some particular job...
...found a picture of the old Cayman up on the same stands.
I have done engine/transmission mounts, fluid changes, spark plugs/coils, catback exhaust and complete suspension swap (coil overs and control arms/links) and getting ready to tackle water pump soon. To date I was able to do all the work myself on jack stands. These cars aren’t that hard to work on.
By far the most frustrating maintenance item was replacing the clutch assist ‘spring’ crammed under the days to fix a clutch squeak and that didn’t even fix the issue - stilll chasing that one.
Thanks for all the feedback. I pickup up the new to me 06' Cayman S, 6spd manual, bose speakers, adjustable seats, in great shape. I put 600 miles on it in the last 5 days. Having a ton of fun driving this car. Just ordered new air filter, cabin filter, oil filter, magnetic plug, plugs, coils, and AOS. Going to do some maintenance this weekend if I can stop driving it for a day! Pulled engine cover off to detail engine bay and it was already really clean. Cleaned it up a bit more and familiarized myself with everything on the engine.
Yes, indeed the Cayman is fun to drive. Do post up any maintenance procedures along with pics. I have posted pics on oil change on 2017 718 here.
www.pbase.com/thunderstrike
No issues but at 80K miles I’d rather proactively replace it instead of waiting for any issues to arise. I have all the parts ready to go but haven’t had time to install it yet.
