Cardan Shaft suggestions, please
#46
There was a lot of flex in the rebuilt shaft, even when installing I could bend it into position. What I didn't realize was the bracket for the center support bearing had to be installed in the same exact position. Still, I figure the shaft shouldn't be hitting the trans tunnel since the new bearing should keep it from banging correct?
I'm on my 2nd rebuilt shaft, wondering if I should bite the bullet and just buy a new OEM one....
#47
Received 1,141 Likes
Thanks for responding
#48
I'll create another thread looking for the tool, would you know the part # of the tool by any chance? Might as well buy it at this point....
Thanks!
#49
The 'by hand' method suggested (and that I used) was to loosen the bolts, give the shaft a good shake, and tighten it where it lands.
#51
Change it yourself in 45 minutes. Vertex two piece. You dont have to remove the driveshaft from the car! Remove support bracket. Push the old steel ring off. Cut with any type of cutting tool, an electric drill with a carbide wheel works just fine. Clean off the area. Install the new two piece part by bolting it together per instructions. Replace Support Bracket....check your work. Zoooooom! Cost, $395. Who knows it may even be better than the OEM replacement which if installed by a dealer is a $1500.00 repair. Ouch!
#52
What he said. Just did this myself after dealer said boot was starting to crack while inspecting other issues. They wanted $2200 parts and labor for a new driveshaft. Spent the $400 for the Vertex/EPS permanent solution and took me under an hour to replace it myself.
