Lets talk spacers
Lets talk spacers
Hey all
I've got a set of 18mm (f) and 23mm (r) spacers set aside at the local H&R distributor for my GTS fitted with 21" sport wheels.
I will also be getting a set of lowering links to lower mildly, somewhere between 10-20mm.
Am I making a mistake? Is the spacers too aggressive?
Paying attention to this thread as I intend on ordering spacers soon. Question though, I was looking at my 955 Turbo with 20x9s and 275s all around; is it just me or does the front wheelbase look slightly wider than the rear?
I'm guessing it's just an illusion, but man the front sure does look wider. I haven't taken a tape measure to it yet, but my need-to-know will force me too.
If it is the same (more than likely is), does anyone run wider spacers in the back than in the front to offset this illusion?
The steps were simple: (A) remove wheel (B) place spacer on hub (C) reinstall wheel with longer lugs. Rinse, repeat.
It's the perfect OEM+ look without it looking too aggressive or pokey. Looks nice at standard ride height and will look even better lowered.
For wheel bolts the following was suggested by H&R:
Front: 54mm (item no. 1455407)
Rear: 59mm (item no. 1455907)
You can get black (painted) bolts from H&R but only the silver ones are available for our p!gs. I paid $7.50 per lug.
I went ahead with the 18mm front and 23mm rear spacers finished in anodized black. Installation difficulty is a 1/10 when it comes to the "DR" style H&R spacers. The DR spacers fit between the hub and wheel, the DRS spacers fit behind the hub (est 4-5 hrs labor).
Any photos of the installed spacers please, I have a 09 GTS.
As far as safety, are comfortable with it?
Confident that the wheel will not come off?
Your're welcome. I have no safety concerns with the extended bolts in place nor H&R products in general.
