Couple Radio Install Questions
Hi all,
New to me owner of a 2008 GTS. I love it... except for the radio. I decided to go with the Dynavin but had a couple install questions.
I have done a lot of searching so please bear with me.
I really need a backup camera, car did not come with one.
thanks in advance for the help!
- Is there any advice on how to run the camera wire from the tailgate to behind the radio?
- Will the radio automatically pick up reverse signal via CAN or do I need to run a relay?
search is your friend
99.9% sure that it gets the signal that you are in reverse from the car without any extra modification. I am basing that on the fact that by default when you turn on the unit and put it into reverse, the screen automatically changes to the reverse view (even without a camera). It also overlays the reversing lines, that change direction when you change direction.
As far as running the cable up, I searched and found this: https://cai-store.com/pages/cayenne-...tallation-tips
If you do not have a camera yet, I would suggest this:https://www.ebay.com/itm/Volkswagen-...NWAt8k&vxp=mtr
It takes place of one of the plate lights so no drilling required to run the wires.
There is no simple way to get from the hatch into the cabin. The super grommets at the hinge are difficult to navigate. Notice how CAI skips over that bit
Everything is pretty straight forward, with the hardest part being the panel pieces on the hatch. Running the cable the length of the cabin above the headliner, down the A-pillar, and behind the glove box was pretty easy.
