Supercharging of Knoxville
Andy,
Funny this should come up. I was just talking to a friend of mine about supercharging yesterday. Thoroughly check your intercooler welds for pin hole leaks. He did a conversion on a track car & they found lots of small pin hole leaks in the welds of his new intercooler. They had the same problem you are describing with holding boost levels at higher RPMs. Give that a shot.
Originally posted by Mark.Budgen
Hello Andy,
although I dont have a SoK kit I do have a TPC .....
Cheers, mark.
Hello Andy,
Cheers, mark.
Hi Mark,
Yes, the TPC kit was my first preferance. I have a few friends here in the UK that have installed that kit with great success. The beauty of it is that you don't have to lower your CR as it is low boost and as you say, the boost is constant through the rev range.
Unfortunately for me, they do not do a conversion (or at least didn't.... and I still think this is the case
All the best
Andy
Originally posted by JW in Texas
Andy,
Andy,
Good call... thanks for the advice. I am in the process of getting a boost and air temperature sensor (I have telemetry in the car), which I was going to fit between the supercharger outlet and the intercooler ontake and then between the intercooler outlet andthe manifold, to try and suss out if it was boost loss or volumetric efficiency breaking down. It sounds like getting a pressure test of the intercooler would be a whole lot easier tho
All the best
Andy
