21 mm master cylinder ?
They did come as oem for part of 1 year, but they haven't been available for decades.
The only currently available choices are 19.05, 23.8 or a custom dual master cylinder set up.
Periodically even knowledgable people claim to have found an intermediate m/c but in every case the lead has turned out to be false. If you find differently let us all know.
If my memory serves, Mercedes has a 21 or 23 that is made by ATE and is about 1/3 the price of the P part. I do have one in my box of stuff somewhere , brand new, if anyone needs a part number. It will require some slight rebending of the brake lines if i remember.
andy
andy
The ATE 23.8mm m/c # 3.2123-1003.3 was used on some MB trucks. It is available form several places(Rennsport systems for one) as a kit which includes a couple of adapters for the feeds and a longer actuation rod. The Ate/MB will only fit if an al. cross member is used. Yes, the feed lines and pressure lines will need a little relocation, as does the mechanical stoplight switch on the older cars.
