ABS 4 channel unit?
ABS 4 channel unit?
I'll got an 996 GT2 RSR that I'll compet in the Swedish timeattack championship whit.
It has an 997 cup 4 channel master cylinder setup.
I'll heard that there should exist some ABS units from boxsters that would work whit my setup.
Are there anybody that have some hard facts about which unit I'll should go for?
Preferably whit suggestions on the right part number.
It should be an stand alone unit whiteout TC and canbus.
You really want the Teves BMW, unit with Motorsports programing, it really is that much better. Or the Bosch Motorsports unit but that's even more $$$$$.
There are a few people on here that can get you set up with one here in the US, but seeing as the setup comes out of Germany I'm guessing if you start asking around in Sweden and Europe then you can find one for less cost. If not then PM me and I can get you set up with one.
Make sure you are getting, the proper Motorsports program and not just a generic Teves BMW unit. You will need to make a little wiring harness, and possibly change out a couple abs sensors depending on which you have already.
Hope that helps,
Viking
Hope that helps,
Viking
