Next step: Infrastructure on the slalom 996T
Hi
With the "best" turbocharger and assuming a boostlevel around 1/1+ Bar (?)
and mainly "mid range" rpm's (?):
* Best Y-pipe? Less pressure drops and/or improved capacity
* Manifold?
* Best plenum?
* Best airfilter and housing?
* Best IC? (Less airflow due to moderate speeds.)
* Best turbo insulator blanket?
* Header for the "best" charger above? Isolated?
* Exhaust, performance! Format has no importance assuming street ok
* Necessary fuel system improvements
* Probably many forgotten items and issues!
Less weight is also an option regarding the exchanged parts.
Thanks in advance!
Slalom996T
* Manifold?
* Best plenum?
Thanks in advance!
Slalom996T
