Agency Power Roll Bars
I'm looking for a roll bar to install in an 05 C2S coupe. I am interested in the Agency Power bar, but there appears to be a problem with the location of the harness bar. Schroth recommends that the mounting point for the shoulder belts be no more that 20 degrees lower than the shoulder. But if you look at the photos on Vivid's site, the bar appears to be at least 30 degrees lower than the opening in the seat.
Is there anyone here that has installed this bar? If so, is it possible to take a look and see if the angle is within the 20 degree max? Thanks in advance for your help.
