Brembo 2-Piece Floating Replacement Rotors for 996 C4S and Turbo
![](http://www.gmpperformance.com/CFJFiles/GMP/17003.jpg)
Brembo 2-piece direct-fit replacement rotors for 996 C4S and Turbo cars that came factory with the 330mm steel front brakes (non-PCCB). These are designed to work perfectly with the factory calipers and pads, and are even finished to match the rear rotors aesthetically.
But because of their 2-piece full-floating design with billet aluminum hats, they are lighter and much more effective at heat dissipation than the stock rotors. These rotors are very similar to those in the Gran Turismo big brake systems, and use the same McLaren hardware.
These are a great option for those of you who would like to keep the stock calipers and improve braking ability at a more affordable price!
Pricing info is on our site here: Brembo 2-Piece Replacement Rotors
Nice rotors......... I have a similar 12 inch floaters with 930 turbo calipers from VCI. Soon enough, I will need to replace the rotors. Where is a good source for them?
I can check with Brembo for you, but I will need some more info. Is the car itself a 930 or are they 930 calipers on a different model?
