how to install RPM for Innovate LC-1
I just received an Innovate LMA-3 and LC-1 package and wanted to know how to wire the RPM channel using the CIS ignition wiring.
I did not purchase the inductive clamp because I thought this unnecessary, tell me if I am wrong.
Was hoping someone here had done this and could explain which wire to use. The tach must receive a signal from somewhere, but I would like to tap into the wiring coming from the engine compartment if possible.
Need to know if the tach signal from the CIS system is compatible with the LMA-3 as well.
Thanks for any info.
Fred
Fred
