Please help ID exhaust parts for 993.
Bought some Supercups last year and along wth them came some odd bits, including these two pipes. They look like they go between header and cat but I am not sure. Made of SSteel and are nice quality. Any help appreciated-even if you can tell me manufacturer-Great!
My guess would be half a cat bypass; these are the bits that join at the end of the manifolds and then you have a "doughnut" joint to the next piece of pipe which then joins, via another doughnut joint, to the exhaust. My Cargraphic sports cats are made up of four bits of which two are similar to these.
Cheers,
David
Cheers,
David
Also, this is an early manifold shape (bent triangle shape, oval hole) rather than a later one (round hole). You probably have the later flange going on your model year.
Cheers,
David
Cheers,
David
