how much horsepower
i am haveing a turbo motor built for my sc and was wondering what horsepower would it produce. does anyone have a way of estimating what it sould have.
1.7.5 to 1 com je pistons, mahle cyl
2. 3.0 crank and rods
3. hi per steel studs
4. new main bering and rod bearings
5. countershaft bearings
6. mag and polish crank
7. carrera cams
8. valve job with silicon bronz guides
9. 37mm intake port
10. port intake system to 37 mm
11. k27 turbo
12. .8 bar wastegate
13. ghl full exhaust
there is more but though it would be irrelevent for horsepower numbers.
it is going to be a 3.2 short stoke with no intercooler trying to keep it stock looking. thanks for any info
7. carrera cams
9. 37mm intake port
11. k27 turbo
I can Help!! I got 320 hp 276 Rwhp on a dyno with a 3.2 engine, turbo,no internal modifications
no intercooler,9.5 standard compression,.5 of non adjustable boost,At this point we are getting ready to drop the engine lower the compression and install the necessary goddies to run at 1.2 bar of boost and 475-500hp,in your set up i think that the biggest problem will be the CSI system and not having a intercooler if i had to guess a number i go with 350 + or -,this is ONLY my guess and is only my 0.02 of opinion.The intercooler will make a big difference.
