23 mm Master Cylindar upgrade???
I'm in the process of upgrading my master cylindar to a 23mm of M-Benz type in my 914 race car (Boxster Calipers front & rear). It appears that the actuating rod at the brake pedal is approximately 20mm short. Does this rod/plunger have this much adjustment? If not, has anybody come up with fix to make new larger master cyl. work??? Thank you.
I just did this and the only solution I could find was to weld an extenaion on the existing rod/plunger.
Since I have a welder, I see welding as the solution to most problems :-)
Jim
Jim
I solved this problem once by using one of the long studs that are used on a 911 crankcase to retain the cylinders. The thread is perfect for the pedal cluster, you cut it to the length you want in the central unthreaded portion of the stud then file the tip to a radius that fits in the M/C.
magistro - I am interested in this:
I've converted to S4 calipers on the front of my '86 951, and am not thrilled with the pedal feel - I believe I've really increased the fluid volume required to actuate the pistons in the front brakes. I am still on stock MC.
How do I know if the stock MC is optimal for this setup? I'm sure there is a formula or ratio for this situation, right? Where do I find accurate info on the volume of the new calipers, and that of the stock MC? How did you know a Benz MC would work in your application? etc., etc.?
TIA
TIA
Originally posted by keith:
<STRONG>magistro - I am interested in this:
TIA</STRONG>
TIA</STRONG>
