987.2 Cayman S. Struts need to be replaced. Help me choose
I have a 2009 987.2 S w/out PASM. I bought the car with GT3 LCAs, Bilstein sport struts and Cayman R springs. The struts need to be replaced and I originally picked Bilstein B8s with the idea of transferring over my Cayman R springs. Now I am second guessing myself.
My car will primarily be used for track. Maybe once a week on the street. I don't have a trailer so I will be driving it to the track as well. I don't do timed events or club racing, just out there to have fun and improve my skills. Are the B8s and R springs good enough for a track-focused set up? Or do I really need to step up to coilovers?
If you are going to strip the suspension off your car, I would start with a Red solid thrust puck in the center of the LCA's both f and r. Then add camber plates in f along with your adjustable LCA's to approach -2.8 camber f and -2.4 r. Add Tarett GT adjustable swaybars f & R. Then add either a single adjustable coilover like Ohlin R&T or a JRZ single controller product. They are easier to setup and you are not constantly adjusting rebound/compression for some reason. If you are serious about racing, then skip this post as you already know what you want to do, spring rate of 600 f and 750 r with dual controller with connectable canisters or use the TPC DSC shocks and controller.
You are asking for other opinions that may or maynot fit your needs. With that said, I use Ohlins with 400 lbs/in f and 458 lbs/in r spring rate. If I were only using my car for the track, I would increase this spring rate using Swift springs and slightly different valving for better compression/rebound control.
- MCS 1-way dampers
- MODE Camber plates and rear mounts
- Eibach springs 600# F and 700# R.
- Tarett sway bars F and R.
