911 Brake tech help
911 Brake tech help
Hi,
I am trying to increase the rear stopping power of my 76 911 race car. I do not want to go full blown big reds or the like because of weight.
I have modified 944 turbo calipers on the front and they work great. I love them, They have never faded or boiled the fluid. I would love to do the same to the rear, but the best I seem to be able to do is get them to mount with about 1/4" of the pad hanging off the top of the rotor because the rotor is not large enough in diameter.
The question is, is there any other rotor that bolts up to my hub directly that is a little larger. I already have the Carrera rotor on it (which I think is a little larger in diameter) but, is the 964 larger and bolt on, or is there some other rotor that will do the job.
Also, I have seen the page on rennlist that is brake tech and talks about the rotor diameter and width, but only the front. Is there a page that talks about the rear as well.
Ed
Ed
Re: 911 Brake tech help
For 944 sizes, you'll have to do some more digging.
TT
