991 C2S/C4S/GTS Tarret caliper studs with Girodisc rotors?
Hi all,
I'm waiting to hear back from Ira at Tarret Engineering but figured I'd ask the question here as well. Anyone running the Tarret brake caliper studs with Girodisc rotors? If so which stud length front and rear and do you need the Tarret spacer kit for the front or rear?
What does Girodisc provide for caliper spacers, I think I've seen 6mm front and 12mm rear?
Thanks!
Thanks!
Basic Sponsor
Hi all,
Thanks!
Thanks!
AS to how long the studs should be....call Ira and ask. The GT3 set up should take an 85MM the stock set up should be 95-100MM....Again call Ira.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
Basic Sponsor
Without the Giro Disc rotors, you'd want the 85mm size studs. The 6mm and 12mm spacers brings it to a theoretical 91mm and 97mm. Our closest sizes are 85mm and 95mm. I think the 95mm size is your only option in back, and has a good chance of working. Used with the 95mm Giro adaptor sleeves. In front, you're right in the middle of the two sizes. It's possible that ether would fit, but we haven't tried it and there's only one way to know for sure. If you'd like to try one or the other or both, you can return whatever doesn't get used.
Ira
Ira
www.Tarett.com | Sales@Tarett.com | 858.674.5573
Check out our new Suspension Package Designer
