Mark this thread as Unsold
2015 GTS OEM PTC rims/tires Agate Grey
Category: Wheels & Tires
Price (no $ sign please): $3500
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911
Location (Region): NorthEast
Item Condition: Used
Tire Rack says tire sizes are the same: Fronts: 245/35-20 Rears: 305/30-20 not sure regarding offsets but am sure someone here will know.
Will be back up in CT Sept 26-28th. I would gladly check offsets, etc., at that time. Tire sizes above. T
Price drop $ 3,500. Wheels are stored at our 2nd home in Wallingford, CT 06492. I'll be there Mon, Sept 26th for two days if you would like to meet to pick up wheels or arrange shipping. Plan is to ship them back to TX if no bites. See 1st post for more detais. TIA 77tony
Found this on the 991 forum:
My 991.1 Targa GTS came with the Turbo S Wheels....Special CXX Order from the factory.
Also: I've spent a lot of time on exactly this issue with my Porsche guys over the past month. As everyone has said, the front wheels are the same. However, the offsets in the rear are different, with the Turbo S at ET 56 and the GTS at ET 48. We believe that the GTS rear wheels will work with spacers on the Turbo S and that the Turbo S wheels will fit on the GTS without mods. T
Guest
Posts: n/a
Hi - I see the pic for the rear wheel at 11J x 20 H2 with offset at 52, which seems in contradiction to the previous replies. Can you please confirm fronts are 8.5J x 20 H2 with offset of 51 and rears are 11J x 20 H2 with offset of 52?
Are the wheels and tires now back in TX or still in CT?
