Mark this thread as Unsold
Agency Power Secondary Muffler Bypass for 991
Category: Accessories
Price (no $ sign please): $400
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911
Location (Region): Midwestern
Item Condition: Used
Up for sales is a set of Agency Power Secondary Muffler Bypass Pipes for a 991 Carrera S 12-15. These were on the car for 200 miles. Going back to stock. They are in perfect condition with little wear.
Looking for $400.00
Product Description
"The first part we built were the Secondary Muffler Bypass Pipes. These simple U/J pipes remove the mufflers that are tucked up in the rear quarter panels. Why the reason for these I do not know. Typically in the past we either see a main center muffler or 2 mufflers with catpipes. So this was the first simplest part to change out. Keeping the same diameter for a perfect OEM replacement, these pipes are straight through which not only eliminates any muffler packing or baffling, but also the weight. Each stock muffler weighs approximately 15. 6lbs. The Agency Power Muffler Bypass Pipes are about 3lbs each. Now eliminating restriction, we have also saved about 25lbs off the rear end. Because this part still retained the factory headers with cats and the factory center muffler, it added a slightly deeper tone to the exhaust but not a drastic droning change that a full exhaust could. Upon revving the car out stationary and on the dyno, you could hear the tone change nicely as you past the 4000rpm mark.
According to our dyno test, the secondary muffler bypass pipes really start achieving performance from 3700rpm all the way to redline. With a baseline test in 3rd gear and all wheel drive (have to for the dyno and no warning lights), the car made 344HP and 289ft/lbs of torque. Based on the ambient temperature, the Mustang Dyno, and 91octane fuel, this is about right considering the car comes with 400bhp. With the addition of our pipes, the car put down 358HP and 298ft/lbs of torque gaining 14HP and 9ft/lbs at the peak."
How much shipped to 33414 west palm beach FL?
