Mark this thread as Unsold
997 wide/narrow body wheels and tires
Category: Wheels & Tires
Price (no $ sign please): $3100
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911, 997
Location (Region): NorthEast
Item Condition: Used
For sale is a set of genuine Porsche 19" OEM forged wheels for a WIDEBODY 997 (Turbo / C4 / C4S). These wheels will fit other models, so check specs below. They are powder-coated black (20% shine) and are in EXCELLENT condition (there is no curb rash or other damage). In fact they are as close to new as you can get while still being used. Also included are 4 genuine OEM center caps which are painted to match. These are not aftermarket rims . . . all the stampings on the hub are there. Here are the specifics:
FRONTS:
19”x8.5” / Offset: +56mm / Part Number: 997.362.156.05 / Bolt Pattern: 5 x 130mm / Hub Center: 71.5mm / Weight: 29.0 lbs
Stampings: Made in Germany, Fr=4200N, 99736215605, RD997, 8.5Jx19H2ET56, plus the Porsche triangle “P”
REARS:
19”X11" / Offset: +51mm / Part Number: 997.362.162.02 / Bolt Pattern: 5 x 130mm / Hub Center: 71.5mm / Weight: 24.0 lbs
Stampings: Made in Germany, Fr=6300N, 99736216202, RD997, 11Jx19H2ET51, plus the Porsche triangle “P”
TIRES:
Yokohama Advan AD08 R compound. These are track tires. Sizes: 305/30-19 rears, 245/35-19 fronts. Mounted and balanced by TireRack. Total cost: $1714
These wheels are very expensive at the dealerships. In fact I was curious to see what new ones go for so I checked out Pelican Parts. The rears currently sell for $2337 each while the fronts are $2237 each. I realize these prices are not grounded in reality, so I’m asking $3100 for the set which I think is fair given their condition and what others are asking for similar sets. If you like the all-black look and you have a widebody, these may be what you are looking for. They would also work perfectly for someone needing a spare set for the track.
The wheels are located in MA, zip code 01569. Local pick up is preferred.
PM me if interested or call 508-641-1078.
