Mark this thread as Unsold
2008 24' United Custom Race Car Hauler - Many Upgrades!!
Category: Accessories
Price (no $ sign please): $19500
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 356, 911, 912, 914, 924/931/944/951/968, 928, 964, 986, 987, 993, 996, 997, Cayenne, Cayman, Carrera GT, Panamera, Race Car
Location (Region): West
Item Condition: Used
time.
Special Raised Floor to accommodate lower cars & race cars to use escape side door
Custom Extra Wheel Storage in Rear of Trailer (can be removed by hand)
Lightweight Aluminum Wheels with New Tires - Less than 500 miles on them
Custom Winch Installation - In Use Mount and Storage Mount
Honda EV 6010 Generator (runs perfect - 31.7 hrs. on it)
Race Ramps - extra-long for loading lower or race cars
Added Security Locks on both side doors
Custom Folding Couch / Bed
Custom Cabinets & Working Counter Top
RB Components Additional Upper Side Cabinets
Added Fire Extinguisher
CO2 Detectors
Fluorescent Lighting
Custom White Aluminum Walls & Ceiling
Added Bull Rings for multiple tie down locations
Added Tracking for fastening items to the walls
Plumed for Air with an external Air Fixture for Air Hoses
Husky Storage Box for tools & extras
45 AMP Intelli-Power Converter for Battery Tending
15 AMP External Outlet Box & Co
ADDED ELECTRICK 5K TONGUE JACK
REESE HEAVY DUTY HITCH SYSTEM AND ANTI-SWAY BARS
FINISH LINE PACKAGE
· - 48" CURB SIDE DOOR W/ CAMLOCK & RV LATCH W/ DEADBOLT
· - RAMP REAR DOOR W/ SPRING ASSIST, 91-3/4” WIDE X 77” HIGH OPENING (2- STANDARD CAMLOCKS ON REAR RAMP DOOR)
· - BEAVERTAILED FLOOR FOR E-Z LOADING
· - (4) HEAVY DUTY RECESSED D-RINGS, (2) 1' FROM REAR & (2) 18' FROM REAR 40" APART
· - (2) 12 VOLT LOADING LIGHTS W/ WALL SWITCH AT REAR
· - POLISHED ALUMINUM WRAP ON REAR DOOR FRAMING
· - NON-POWERED ROOF VENT (REAR VENT)
· - WHITE VINYL CEILING LINER
· 8.5' WIDE X 24' LONG X 6' 6" INTERIOR HEIGHT
· GVWR: 9,990 LB
· EMPTY WEIGHT: 4,580 LB
· JUMP DOOR OVER WHEEL WELL ON ROAD SIDE W/ CAMLOCK - 48" WIDE X 58" HIGH, 9-1/2" OFF OF FLOOR & 7' 7" FROM REAR
· 6-LUG 15" ALUMINUM WHEELS (CLEAR COATED) IN PLACE OF STANDARD STEEL WHEELS
· EPOXY GLUED EXTERIOR PANELS (SCREWLESS EXTERIOR)
· DIAMOND PLATE FLOORING
· ALUMINUM INTERIOR TRANSITION FLAP W/ HINGE FOR RAMP DOOR (HINGE COVER)
· 11/32" WHITE VINYL INTERIOR WALL BOARD
· (2) ADDITIONAL HEAVY DUTY RECESSED D-RINGS, 21’ FROM REAR 32” APART
· FRONT ROOF VENT BRACED & WIRED FOR A/C
· INSULATED CEILING
· 36" WIDE X 30" HIGH GENERATOR DOOR (VENTED)
· CARBON-MONOXIDE DETECTOR (BATTERY OPERATED)
· ALUMINUM CABINET PACKAGE ACROSS FRONT WALL
· MILL FINISH ALUMINUM WORK BENCH TOP
· 110 VOLT ELECTRICAL PACKAGE "A" -
· (2) 8' DOUBLE TUBE FLUORESCENT LIGHTS, (1) ANGLE-MOUNTED IN CURB SIDE COVE 4' FROM REAR & (1) ANGLE-MOUNTED IN ROAD SIDE COVE 4' FROM FRONT
· WALL SWITCH FOR FLUORESCENT LIGHTS AT CURB SIDE DOOR
· (2) INTERIOR DUPLEX RECEPTACLES, (1) ON FRONT WALL ABOVE WORK BENCH & (1) ON CURB SIDE WALL AT REAR
· 30 AMP ELECTRICAL PANEL
· COLOR: RED SCREWLESS EXTERIOR
· STANDARD FEATURES:
· (2) DEXTER 5,200 LB INDEPENDENT TORSION SUSPENSION AXLES
· ELECTRIC BRAKES ON ALL WHEELS
· E-Z® LUBE HUBS
· ST225/75R15E 10-PLY RADIAL TIRES
· NITROFILL TIRES (NITROGEN)
· 7-WAY RV MOLDED PLUG
· 2-5/16" COUPLER
· SAFETY CHAINS
· BREAKAWAY KIT W/ CHARGER
· STEEL UNI-BODY CONSTRUCTION
· 16” ON-CENTER FLOOR CROSS MEMBERS
· 16" ON-CENTER WALL POSTS
· 16" ON-CENTER ROOF BOWS
· UNDERCOATING ON LOWER FRAME
· (2) 12-VOLT DOME LIGHTS W/ WALL SWITCH AT CURB SIDE DOOR
· .030 SMOOTH ALUMINUM EXTERIOR
· ONE-PIECE ALUMINUM SEAMLESS ROOF
· LUAN REINFORCEMENT LINING UNDER ENTIRE ROOF SHEET
· AERODYNAMIC ROUNDED FRONT END
· POLISHED ALUMINUM FRONT CORNERS
· ALUMINUM FENDER FLARES
· ALUMINUM TREAD PLATE STONE GUARD
· WEATHER GUARD COATING ON FASTENERS
I had a Continental Cargo 24' built for me and had it speced with as much as they could muster given the short lead time I was working with. Several doors, 5200lb axels, finished, power, leds&flourescents, flood lights, locks, matching paint with my truck, TireRack and plenty of fastening points.
Having issues linking pics from iPhone will try from PAD.
