Mark this thread as Unsold
Clear Side Marker Lights - 997.2
Category: Exterior - Body Parts
Price (no $ sign please): $35
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 997
Location (Region): SouthEast
Item Condition: Used
These are original Porsche OEM clear side makers, they came off of my 2011 CAB that I recently upgraded to a 991 CAB.
Price $35.00, delivered in the lower 48 states.
This is a complete set of factory clear side markers. These will install in seconds, and come with the correct amber bulbs. These are Porsche Original equipment on European cars! Take advantage of this great deal!
Clear Side Markers Installation
If you're looking to complete the European look of your car, the factory clear side markers are an inexpensive and easy fix. This guide is for 2005-2012 Boxster, Cayman, & Carrera models. Installation is a breeze.
Tools Required: None
Removing the side markers doesn't require tools, it's a fairly simple process. By approaching the side markers from the wheel-well, you can easily pry the release clip. Be gentle, but firmly pull the backside towards you. The clip will bend, and the backside will be released. Pull the light out, pay attention to how it was installed (this will help when you are reinstalling the new lights).
Next, you will have to unplug the wiring harness. There is a metal spring clip, push it down. This will release the light completely. So that's the hard part, now it's time to install the new (and pretty) clear side marker. Push on the metal spring clip again, and install it on the clear side marker until it locks into place.
To install the lens, start with the front tip. You will notice there are two guide pins, they will slide into the appropriate slots in the front. Make sure that the wiring harness will not interfere with the installation, then gently swing the back end in place. It should click into place, then you're done!
Now it's time to check the bulb operation, turn on your parking lights and make sure they are working properly.
