Mark this thread as Unsold
AIM MyChron3 Plus
Category: Accessories
Price (no $ sign please): $450
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): Other Marques
Location (Region): Texas
Item Condition: Used
$450 includes shipping to contiguous 48 states.
The MyChron3 Plus is a powerful instrument for kart racing that combines a wheel speed gauge, gear position indicator, two temperature gauges, a tachometer, lap timer, and data logger into a compact unit that easily mounts to your steering wheel. It is a digital dash, gauge, and data logger with gear position display, wheel speed display, graphical and digital RPM indicator, automatic lap time, and two temperature inputs for exhaust gas, cylinder head or water sensors.
Connect a few sensors to the MyChron3 and it displays, samples, and stores the data from those sensors. For example, you can connect a temperature sensor to the cylinder head of your engine and get continuous reads on your engine temperature. See the temperature values on the display as you drive, and download the recorded data to your PC and review the numbers on a graph later on. AiM Sports uses sophisticated data acquisition technologies in the MyChron3 to make this process fast, accurate, reliable and cost-effective.
The MyChron3 Plus is a self-contained, true data logger that acquires data from all connected sources 10 times a second. Using our powerful Race Studio 2 software you can download your data to your PC and get a professional analysis of your performance data. You can also replay the data on the MyChron3 without a PC or software. With 512 kb of memory, the MyChron3 Plus stores over 60 minutes of data (up to 315 laps). The MyChron3 Plus features non-volatile memory, retaining data even when the power is off, and has an Auto-Power off feature to preserve the battery life.
The MyChron3 Plus is suited for gear engine karts, race & performance cars and motorcycles. Featuring a wide, backlight display, the MyChron3 gauges are fully configurable – putting you in full control of what you see on the screen.
MyChron3 Plus Kit Includes:
• MyChron3 Built-in data logger
• Infrared transmitter and receiver
• RPM pick-up
• 1 temperature sensor (your choice of CHT, EGT, or H20)
• Wheel Speed sensor
