Mark this thread as Unsold
G50 gearbox and ancillaries FS
Category: Drivetrain
Price (no $ sign please): $5200
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911, 964, Race Car
Location (Region): SoCAl
Item Condition: Used
I recently purchased a running and road-tested 3.2 drivetrain and have decided to part with the G50/5-speed gearbox (open dif) and related conversion pieces as a package. There were no docs or working speedo on the vehicle, an '81 SC with a 959 body kit. However, all is fine. Shifts good; synchros good.
This gearbox (87-89) has a short nose and will easily fit earlier 911s with very minor modifications to clear the torsion bar tube.
Here's what's included. SOLD
- G50-01 5-speed gearbox as equipped from 87-89 911 with aluminum gearbox mount, clutch slave cylinder/hose and speedo sensor.
- Starter ring gear
- Matching Bosch starter motor
- Sachs Race Engineering 240mm Turbo aluminum pressure plate (11.95 lbs). , part no. 88 3083 999 574; TYP GMFZ 240. List price for the pressure plate alone is $1465.74
- Turbo clutch disc w/TO bearing
- 3.2/G50 conversion flywheel/pilot bearing. Clutch/flywheel package looks relatively new. Excellent condition.
- G50 Shifter assy
- G50 Shift tube
- G50 Shift coupler
- G50 pedal assy. with clutch master cylinder
- Dual fluid reservoir w/mount bracket for brake and clutch circuits
Sherwood
PM may be full in which case send email inquiries to slee632@yahoo.com
