Mark this thread as Unsold
987.1 Roll Bar and Harness bar
Category: Interior
Price (no $ sign please): $1
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): Cayman
Location (Region): NorCal
Item Condition: Used
Rollbar w/ Harness bar out of my 06 Cayman. $850 make offer, Motivated Seller
<br />Custom built for the previous owner and now being brought back to a more street-friendly / track car. OEM seats will fit without issue with roll bar installed. I removed the rollbar since (and Recaro halo seat) and before temporarily placing the OEM seats while searching for buckets. They fit very well (pass seat was in there the whole time), with me at 6' & 180lb using OEM seats.<br />Rollbar was secured in front to plates welded into floor. It appears to be another relatively easy install (simple for body or perf shop) for the next owner -either with bolts through floor or welding in another mount plate behind each seat. Rear rollbar mount points are simple bolt-in to strut towers and provides additional integrity to rear suspension.
<br />I almost kept the rollbar intact but decided not to deal with notching carpet and cutting rear trim to accommodate the rear mounts.<br />Located in Reno, NV, and shipping 2 large objects would be ugly, if so desired. Prefer pick-up.
<br />
Shameless bump with pic for attention.
This rollbar / harness combo was built by Infinite Velocity Motorsports in Reno at about $2k for the last owner.
Asking $850 or make offer.
Hey, I’m interested but not really looking to drill/weld. Can you confirm this doesn’t use the stock Boxster roll bar mount points? I’ve seen some other rollbars that do, thought this might as well. Thank you!
Hello,
This rollbar will need to have holes drilled OR plates welded behind the seats to attach it. Rear mounts are shock towers and simply bolt on.
This might not meet your wishes.
I have been asked for shipping quotes and I grabbed a few random cities to give folks an idea....
Ocala FL: $554
Springfield IL: $525
Los Angeles 90003: $430
Portland OR: $460
If fuel prices change much, an increased surcharge of 25-35 bucks can be expected.
These prices are PACKED and SHIPPED.
Ocala FL: $554
Portland OR: $460
