2017 Climate control HELP
Every time I get in the car, the temp is at 72 with the driver vent on only. I have to manually switch on the passenger side vent and turn up or down the temp.
Is there a way to start the car and have the temp and vents set to the last setting? This is beyond annoying to have to reset the temp and vents every time I get in the car especially after I just clicked 4 different buttons just to turn on the vents and reduce the temp.
On the older model with manual vents you just set the temp/fan the way you want and then save the current settings to your key and/or number setting. You could also check a value in the car's settings that has the car remember the last settings.
