Panamera Spare Tire-Lack thereof...
#31
I opted to buy tire plug kit. $2.49 including tools, plugs (5) and cement.
If needed, can plug tire, use compressor tyo inflate. No need for hauling another tire around.
Would feel like the 5th wheel.
#32
Puncture plugs and tire goop are fine ( I carry both)...if all you have is a simple puncture. If you have a more serious failure, you are at the mercy of Porsche roadside assistance and a replacement tire actually being available.
I carry a spare* if I am going on a distant trip......
*includes a jack, lug wrench, etc.
#33
I picked up a front rim and wheel off ebay from a wrecked car and works well. I only have to buy a suitable jack for the kit I put together. I am debating on regular scissor jack or a 911 jack like the one in this thread. I will use for long trips as I don't want to get stranded in the Arizona desert or anywhere between here and the Rockies I road trip frequently.
Any suggestions for compact jack? I was thinking a bottle jack even but not sure. I have the tire mounted (same as current daily Michellins), a breaker bar and 19mm socket, wheel patch kit for hole repair so far. A jack and a tie down is all that is left. My experience with my Saab and Benz are complete destruction of the sidewall so I won't travel far from home without a full-size spare.
I paid $379 with free shipping on ebay for a 20x9.5 inch Panamera wheel and tire with 70% read life left in the same size as my current setup. Not bad. Even has tpms installed.
#34
Part number for only the OEM 970 scissor jack is "971-011-031", if you are interested. A piece of 3/4" plywood for stability underneath the jack would be helpful on uneven/unstable surfaces. A pair of is also helpful.
#35
I have a Panamera GTS with 20" wheels. I just replaced my expired tire sealant.
Questions.
1. What happens to the sealant that makes it expire?
2. I know you should not exceed 50 MPH on a sealant repaired tire.
What is the approximate distance you can drive on a sealant repaired tire? For example, could one drive a distance? Does the sealant hold up overnight if needed? (Dealer not open, etc.)
I hope to never need it, but knowing what to expect would be useful.
Questions.
#36
Porsche part #Compact Spare Part #970-362-050-00 Will go on on either front or rear, get a low profile flex jack and you are safe to go. All very compact and offers more security than sealant.
#37
I like the idea of the compact spare tire noted above. My wheels are 20" and the 20" compact spare (970-362-070-00) costs 2X that of 050-00. Any idea if i could still run the 970-362-050-00?
#40
what's a low profile flex jack? Now that I do have a full size spare, I'm looking to complete the necessary accessories for changing a tire. The oem jack is over $200, so hoping for something a little less expensive. (should have pilfered the jack out of my 911 as it could have been compatible)
#41
I bought a 911 jack with the foam insert off ebay for $100. fits perfectly in the side 'pocket space' of the the hatch. cheater bar, piece of small plywood for the jack, and socket in with the bose amp/battery area. I am guessing flex jack is a scissor jack?
#44
Have you tested the 911 jack on your panamera? Indeed there are plenty of them on ebay.
#45
Yes. it is the same as the one in this thread post 12. https://rennlist.com/forums/panamera...l#post13989175
I put a piece of plywood 6"x6" or so for support if on dirt just case also in the car.
