standard Pana 4 stock exhaust
What is the function of the vacuum part on the rear of the exhaust system(right by the tips almost). I assume there is a hose connected? I saw a post on this weeks ago and can not find the info.. any exhaust note change by disconnecting?
OK, forget that as I do not have that set up. I do have one pipe exiting the rear muffler with a second hole that s capped off... wonder if adding that additional pipe would be the sport exhaust??
second exhaust outlet
Same here....did you open the second outlet exhaust hole? if so how did it work/sound? any changes in performance? What I don't want to happen for v6, is sound good but negatively affect power...
