Panamera Horn Location and Access
Low horn is out
If my understanding is correct, the horn is made up of two separate horns, a high and a low tone. Your low horn is out, as are the ones on many early Panameras, including my 2011 Turbo. A common problem that, I was told by a Porsche service tech, was due to a change in horn manufacturer. The problem has been corrected with a redesign and if you buy a used horn from a newer model it should hold up fine. Unfortunately, I do not know exactly how new, but my sense of it is for sure the 2014 on.
I have not undertaken the replacement, but am glad to know in advance that the bumper (cover) needs to be removed.
Here is the link to the other write up (on this site!):
https://rennlist.com/forums/997-foru...r-removal.html
Ed
Ed
