Thoughts adding tt to a base Panny
That's a fair point. While I'm not in the market for a base Panamera, and never will be, if I were, I'd assume that an aftermarket turbocharger had done terrible things to the reliability of the car. I'd never buy one. If I wanted more than the base 310 HP, and I were buying used, I'd only consider cars which were designed with the higher HP in mind.
It's different if you're looking at a car where there are no higher power trims available. If I wanted a Cayman with 400+ HP, my only choice is a car that's been modified with a 3.8L engine or a turbocharger. Factory cars don't come with that level of power.
