Panamera 2010-Current
2014 Panamera 4S executive
Old Jun 14, 2014 | 08:47 AM
garyc29's Avatar
garyc29
6th Gear
Default 2014 Panamera 4S executive
Hi there
Does anyone here know how to keep the stop and go function off every time u start the car?
I have to manually turn it off everytime after I start the engine, anyway I could set it up so it stay off as default setting?
Thanks in advance
Old Jun 14, 2014 | 10:58 AM
hzoenvy33's Avatar
hzoenvy33
It's not possible due to regulations.
If a car maker says "we can do XY mpg with this car" the car must always start in the "setting" that should achieve this rating. That's why "Sport" Mode is also turned off every time you re-start.
Old Jun 14, 2014 | 01:42 PM
Panaseeya's Avatar
Panaseeya
Is this a U.S. car? Once I turn it off it stays off with my '13 GTS.
Old Jun 14, 2014 | 02:52 PM
ace10's Avatar
ace10
"Stays off" until you cycle the ignition again, or "stays off" until/unless you decide to turn it back on at some time in the future?
Old Jun 14, 2014 | 03:07 PM
Panaseeya's Avatar
Panaseeya
Stays off until you turn it back on. It has been off close to 2 years now and I've never had to touch it again.
Old Jun 15, 2014 | 02:11 AM
garyc29's Avatar
garyc29
6th Gear
it's not a us car, I am located in Shanghai, China
Since this car is imported directly from Germany, I expect them to be the same in turns of software...etc
Stays off means it will have to be manually turned on again rather then one ignition cycle
Thanks guys for all ur help
