'12 Porsche Panamera Turbo w/ Vorsteiner kit, SpeedART Power Kit, ADV1 Wheels & more
The Panamera is naturally deceptive. With its size and weight, it usually shocks a person just how quick and effortlessly it moves itself around. With this latest project, we're going to enhance that deception even further.
Similar to a building, it all begins on a strong base with a ton of small details that make a big difference. Add a little (or in this case, a lot) of visual pizazz and you will have an idea of what the end result will be when we're all done with it.
On the performance checklist is a 16" Brembo Gran Turismo big brake kit, Sprint Booster system, as well as a power kit by speedART, which includes Sport mufflers, mid pipes, high flow cats, ECU upgrade and intercoolers.
And what's a sports car without a little show? This Panamera will be sent off and fitted with a full Vorsteiner body kit, custom paint and red carbon fiber interior, Hofele spoiler, and ADV1 wheels. Even the pedals get some new style as we replace them with aluminum tiptronic sport pedals.
Needless to say, this Panamera is guaranteed to earn more than its fair share of double takes and turned heads as it cruises the streets, heavy, powerful, and incredibly stunning.
Parts Included:
Brembo Big Brake Kit
3-Way Adjustable Sprint Booster
speedART Turbo ECU Upgrade
speedART Carbon Engine Cover in a custom color
speedART Turbo Power Kit I
Vorsteiner V-PT Sculpted and Vented Rear Bumper Cover w/DVWP Flat Bottom Panel
Hofele Rivage GT Turbo Rear Spoiler
Vorsteiner V-PT Vorsteiner Front Bumper, V-PT Front Bumper Cover DVWP Including Carbon Fiber Lower Splitter and V-PT Front Bumper Optical Carbon Fiber Intercooler Ducts
Vorsteiner V-PT Full Carbon Fiber Sculpted Side Skirts
speedART Custom Color Seat Belts
speedART Colored Gauge Face and Instrument Dials
speedART Custom Colored Carbon Fiber Interior Trim
speedART Sport Pedals
speedART Lowering Module
ADV1 ADV5.2 Wheels
BMC High Flow Air Filter
To the build!
Interior Removal and Installation
Out with the old...
In with the new!
speedART gauges
All lit up
speedART Exhaust
When you have big projects like this, the probability of never hitting a single snag is extremely rare and the Panamera was no exception to that rule.
The SpeedArt exhaust system which was selected was designed to work with both the factory Porsche rear fascia and the SpeedArt body kit, but unfortunately the tips sat too low to fit with the Vorsteiner body kit.
Once the Vorsteiner bumper was installed, we found the geometry of the tips would not allow them to properly fit into the openings of the bumper. The bumper was designed to fit a very basic tip, and the opening is very narrow. The speedART tips are very large (100mm each) and required an exact fitment. In addition, the fabrication of the tips were done at certain angles.
To retain the tip design, we had to disassemble the tips by cutting them apart into sections, and fabricate new angles to weld in. Then the tip itself had to be removed from the piping by hand cutting the old welds off because the tip style had to be rotated to form a correct alignment. The tip piping was measured, fabricated and then tacked together.
The tips were then repeatedly installed and torqued to spec throughout each additional tacked piece to insure that the tips were fitting correctly. Once the final pieces were tacked in place, the piping was welded all around. After they were completed, they were installed and adjusted to fit. The car was driven to get up to temperature and then they were adjusted to make sure there was clearance during expansion. The tips were then sent to get powder coated to match the wheels. Once they arrived back, we had to sand the tips at the mounting points to get them to fit and then install, adjust and torque them. A number of modifications were required, but in the end the result was worth the effort.
Stock tips and exhaust
New one installed
Something doesn't look quite right here...
Back to the drawing board
Through ingenuity and lots of work, they all get done. And it's totally worth it.
Powder coated, installed and all finished
The Brembos
Before And After
Our customer came wanting something unique, distinct and one-of-a-kind and we were happy to deliver. All in all, we're quite proud of this build and we enjoyed every part of it. This one will definitely leave a lasting impression on anyone who sees it around town.
For more on this build and to see all 352 photos, including more on the power kit, lowering module and high flow air filter, visit our gallery here!
Parts Included:
ADV1 ADV5.2 Wheels
To the build!
Out with the old...
In with the new!
speedART gauges
All lit up
speedART Exhaust
New one installed
The Brembos
Before And After
Where do you get red sport chrono faces? Do you sell them? Stunning!!
I really like the gauges too, as you can probably see by how many gauges picture I included when building this post! Haha
The gauges are made by speedART. Since GMP Performance is speedART's sole US distributor, we are lucky enough to offer them exclusively.
http://www.gmpperformance.com/index.cfm?PG=detail&PID=223312
Send us a message if you have any questions.
http://www.gmpperformance.com/index....ail&PID=223312
Okay .. I'll take the heat .... not a fan of the black hood and I absolutely hate the interior ... especially the red gauges .. While many on this board claim to "love it" ... I'd bet most wouldn't buy a Panamera decked out in this fashion ... owner is going to take a hit when he sells also ... BUT ... his car and he should do what he likes .... craftsmanship looks top notch
You're not the only one, though I admire the work (and changing gauges takes about 2-3 hours in other Porsches I have done) I do not find the outcome appealing at all. I think these cars look best with subtle changes like the sport design kit but as soon you start going all out they start looking like clown cars. and I really do not like the big wheels I wonder how much weight and mass those things are adding to the car.
[QUOTE=PCC;10323431]Okay .. I'll take the heat .... not a fan of the black hood and I absolutely hate the interior ... especially the red gauges .. While many on this board claim to "love it" ... I'd bet most wouldn't buy a Panamera decked out in this fashion ... owner is going to take a hit when he sells also ... BUT ... his car and he should do what he likes .... craftsmanship looks top notch[/QUOTEY
my kit for sale
I just sold my Panamera and am nowselling my Vorsteiner bodykit as well as my Wurde.jp rear bumper+diffusor, Techartslip-on exhaust pipes, Modulare B18 21 inch front+rear wheels in Basaltblackmetallic and the matching summer and winter tyres (2x Michelin Pilot SportAlpin PA4 Front 245/30 R21 91W, 2x Michelin Pilot Sport Alpin PA4 Rear 295/25 R21 96W, 2xMichelin Pilot Super Sport Front 245/30 R21 91Y, 2x Michelin Pilot Super Sport Rear 295/25 R21 96Y).Summer tyres are about 60% and winter tyres around 70%.
The Vorsteiner bodykit consists of: VorsteinerV-PT Front bumper, Vorsteiner V-PT Blinker Covers, Vorsteiner V-PT RadiatorDucting, Vorsteiner V-PT Side Skirts, Vorsteiner V-PT Ducktail
Price for the whole set is € 10.000,- excl.VAT (original price € 22.861,04 excl. VAT).
Delivery withing Europe is € 500,-, deliveryto the United States is € 1500,-
Contact me at Mareno@yes-salons.com
Here some pictures of my car with thefull kit:
