:: ECS Tuning :: Exact Fit Stainless Steel Brake Lines
Former Vendor
![](http://www.ecstuning.com/sales/ecs600header.jpg)
![](http://www.ecstuning.com/marketing/Porsche_Panamera_ECS_ExactFit_StainlessSteel_Brake_Lines/Porsche_Panamera_ECS_ExactFit_StainlessSteel_Brake_Lines.jpg)
If you spend time and money renewing your brake hardware and linings, you ought to consider upgrading to ECS Tuning Exact-Fit brake hoses, and do the job right. These premium brake hoses are stronger, more durable, and better protected than the originals.
They are shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection. Available by the axle for front or rear, or as a complete vehicle set, our DOT-approved, tailored hoses fit like OE for hassle-free installation.
Click Here for more information and to purchase
Former Vendor
![](http://c1552172.r72.cf0.rackcdn.com/360809_x600.jpg)
What's the best part about ECS Exact-Fit brake lines? They fit to your car exactly as they were intended, with no modifications necessary. They have also been approved by the Department of Transportation for highway use, having been tested up to pressures of 3000 psi. These High quality brake lines are in stock and ready to be shipped !!
Former Vendor
![](http://c1552172.r72.cf0.rackcdn.com/360811_x600.jpg)
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. This expansion is even more prominent in aged and weathered rubber hoses. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Additionally, exposure to the elements can cause rubber lines to soften and swell over time, increasing the potential for a soft, mushy brake pedal, or worse, complete failure. ECS Exact-Fit stainless reinforced lines, however, are coated in out signature red vinyl to provide protection from the elements, and prevent this type of failure.
Former Vendor
The steel braiding won't allow the brake lines to expand as much as rubber lines. When brake hoses expand, it creates a squishy feeling in the pedal, and reduces the effectiveness of your braking, since some of the force is applied to expanding the hoses, rather than pushing the pads against the rotors. This gives you a better pedal feel. They also should last you the life of the car with out any problems.
