Panamera 2010-Current
Rough idle, throttle hesitation...
Old Aug 31, 2012 | 05:40 PM
kip1's Avatar
kip1
Default Rough idle, throttle hesitation...
-What can cause rough idle and throttle hesitation? O2 sensors? Catalytic converter? Oil separator? And no fault code except faulty oil pressure gauge + check engine light.
-What can cause bouncing oil temp gauge, faulty ground? Oil pressure gauge was just replaced
Old Aug 31, 2012 | 05:50 PM
ECS Tuning's Avatar
ECS Tuning
Former Vendor
I would say your best bet is to scan it and go from there. The only thing I've seen like that on a Panamera was a bad high-pressure fuel pump causing rough idle and throttle hesitation.
Old Aug 31, 2012 | 06:06 PM
kip1's Avatar
kip1
Dealer is saying its the faulty oil pressure sensor, but that is bs right?
Old Sep 4, 2012 | 11:18 AM
ECS Tuning's Avatar
ECS Tuning
Former Vendor
It seems like a stretch, but it's possible that the rough idle is due to the demand-controlled oil pump repeatedly switching between high and low pressure due to a faulty pressure sensor.
Old Sep 4, 2012 | 03:54 PM
kip1's Avatar
kip1
I was hoping it would have, but they installed a new one allready.
Old Sep 4, 2012 | 04:39 PM
ECS Tuning's Avatar
ECS Tuning
Former Vendor
What year is your car ? Was it covered under warranty ?
Old Sep 5, 2012 | 06:48 PM
kip1's Avatar
kip1
2010. Yes the car was towed due to oil pressure monitoring failure code.
Old Sep 18, 2012 | 12:12 PM
ECS Tuning's Avatar
ECS Tuning
Former Vendor
So did the dealership give you a reason for the failure ?
Old Sep 19, 2012 | 05:07 AM
Eugene-Taiwan's Avatar
Eugene-Taiwan
I also have a 2010 turbo with a bit of a ruff idle.
but not fault codes
Old Sep 20, 2012 | 03:47 PM
kip1's Avatar
kip1
They fixed the faulty oil pressure sensor and after they did this, my oil temperature sensor has now started jumping up and down. They have contacted Germany, but no answer yet. Frustrating.
After the turbo recall, my car has now otherwise performed better than before, hesitation seems gone. Although have only had the car for a few days. Im guessing my turbos were failing
Old Sep 20, 2012 | 03:51 PM
kip1's Avatar
kip1
but not fault codes
Please post if you find out something. My car seems better after the ti-al turbo recall, but the cold weather is only starting so will see if it starts again. My rough idle was worse when cold.
