Whining noise?
Whining noise?
I've experienced it in a test drive, and I was just watching this YouTube video (Top Gear outtake) and noticed it around 1:00 mark. Is this what others are experiencing?
You know it is really odd that you posted this. On my new GTS within 2 days of commuting I noted a really faint but annoying high pitched noise, almost seemed like feedback from a microphone. I called my local dealer and he wasn't aware of any similar problems. Now that I read this post I searched and found other people have had similar issues. This was definitely not present in my prior PTT. Its funny because the noise is at first barely noticeable, only occurs at higher speeds while cruising. But once its noticed, oh my god is it annoying. It seems like it has to be something involving the driveline because it noticeably fluctuates with throttle input. Also, doesnt occur when parked and revving the engine. Will be visiting the Porsche dealer sooner then expected.
On a side note, other then this crazy noise I really enjoy the GTS.
Sorry you have this issue, I have observed the same on my '13 GTS. There is a good thread on 6speed with a few others with the same problem. Closing the right middle air vent does dampen the sound and make less annoying. Let's hope with multiple people reporting the same issue that a fix can be found. I agree otherwise the GTS is a fantastic package!
Yes good point. There seems to be 3 different sources for high-pitch whistle/whine in the Panamera, this is based on my searching to find a source for my problem on various forums:
1. High pitch whistle coming from the rear boot-lid seal/insulation. Can be diagnosed by taping up the rear gap. Replacing insulation can minimize the issue, though physically realigning the rear trunk lid apparently eliminated the noise.
2. High-pitch whistle coming from the steering column area under turns. This is a power steering fluid pump or fluid level issue.
3. High-pitch whistle from the middle console air vent at high speeds. Can be diagnosed by closing the middle right air vent which diminishes the sound. The noise also disappears when vehicle is put in neutral while coasting at the high speed which causes the sound, and seems to be associated with AWD vehicles. This implies a front drive-train issue, but currently unresolved. This is what I have.
Thanks for confirming. Very sorry you have the issue, but I am glad it is "real" and I am not just imagining. If more people report this hopefully it will get addressed.
http://www.youtube.com/watch?v=9ftrk...feature=fvwrel
http://s298.photobucket.com/albums/m...9102011012.mp4
http://www.6speedonline.com/forums/p...er-speeds.html
Thats my car with the rear whine before the rear hatch seal replacement Sorry, wrong whine...
