Hot Out There? Prestige PhotoSync Nano Window Film is THE SOLUTION
Here's another Panamera GTS with Spectra PhotoSync nano tint.
The tint shade is at 75% for the windshield and 65% for the sides and rear. The percentages represent the amount of light going into the vehicle, so the higher the percentage the lighter the film. For comparison purposes, OEM glass are typically rated from 85%-88% VLT (visible light transmission)
Amazing heat rejection - 98.5% of infrared block! Most window tint on the market only produces 20% - 30% of infrared rejection. Even for the ceramic tints, they achieve between 70%-80% depending on brand.
![Name: 1.jpg
Size: 94.6 KB](https://rennlist.com/forums/attachments/panamera/1236071d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-1.jpg)
![Name: 4.jpg
Size: 49.7 KB](https://rennlist.com/forums/attachments/panamera/1236072d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-4.jpg)
![Name: 1.jpg
![Name: 4.jpg
![Name: 11.jpg
Size: 75.0 KB](https://rennlist.com/forums/attachments/panamera/1236073d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-11.jpg)
PREMIER PROTECTIVE FILMS
ClearGuard PPF Specialists, Spectra PhotoSync IRD & CeraLuxe IRD, Authorized Modesta and Nanolex Dealer
www.facebook.com/premierprotectivefilms
B: 510-623-1308
sales@premiermobilegroup.com
See Our Projects! http://www.facebook.com/premierprotectivefilms
CLEAR BRA CLEANER -TRACK MARKS ON CLEAR BRA - PF1 TTR!
http://www.premiermobilegroup.com/pf1_products.shtml
B: 510-623-1308
Weather's heating up in many parts of the world now. Consider Spectra PhotoSync as it's the best heat rejecting film that we've tested to date. Here are some photos of various shades on wide variety of cars:
'12 Turbo with Spectra PhotoSync45% Sides + 75% Windshield
![Name: 5_zps9b2e9843.jpg
Size: 109.0 KB](https://rennlist.com/forums/attachments/panamera/1236074d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-5_zps9b2e9843.jpg)
2013 Cayenne Turbo with Full Mansory Kit ($80,000 kit!!!) - Spectra PhotoSync 35% all around
![Name: 4_zpsc5cd75b4.jpg
Size: 78.4 KB](https://rennlist.com/forums/attachments/panamera/1236075d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-4_zpsc5cd75b4.jpg)
2011 GT2RS with Satin Guard Paint Protection Film + Spectra PhotoSync75 Sides + 75% Windshield
![Name: 40.jpg
Size: 113.1 KB](https://rennlist.com/forums/attachments/panamera/1236076d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-40.jpg)
A video we just created to show how well Spectra PhotoSync performs even on 75% VLT (this is pretty light compared to factory glass at approximately 88%)
The windshield of this Tesla Model S has the 75% PhotoSync on the windshield. In just twenty minutes time, the surface temperature difference is 20 degrees. Again, this is with a 75% film, which is extremely light for window film (no longer have to go dark to block heat)
We just installed Spectra PhotoSync 75% to the windshield of a Tesla. Right here, we use a BTU meter to test the performance of the product installed - what a difference!
We recently conducted a test to see how hot the Tesla Model S gets in the rear. There is a general consensus among Tesla owners regarding too much heat build up. For the rear hatch of the Tesla Model S, there is an option for rear facing seats for children. Owners of the Model S have been complaining and executives at Tesla even know of this issue. With that said, we decided to conduct a test to measure the ambient air temperature of the rear hatch. Tesla's rear hatch glass is a laminated glass that has a metallic coating to it to reject some heat; however, even this is not enough from our findings.
Though this is not a 991, we believe it is necessary to show the efficacy of every product we carry at Premier. Below is our test:
Test Subjects - 2 Tesla Model S
Tesla 1 - factory laminated OEM Glass with metallic coating
Tesla 2 - Spectra PhotoSync 45 installed to the side glasses + rear hatch
30 Minute Test in the Rear Hatch with both vehicles side by side
Duration: 30 Minutes
Time of Test: 3:35 pm
Exterior Temperature: 88 degrees
Purpose: Compare air temperatures inside hatch between vehicle with no window film and the other with Spectra PhotoSync installed
Here are the two test mules:
![Name: IMG_9955_zps2fa7187c.jpg
Size: 76.8 KB](https://rennlist.com/forums/attachments/panamera/1236083d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-img_9955_zps2fa7187c.jpg)
Test Vehicle 1 - No Film
Start off at 84 degrees
![Name: BEFORE1_zpsb03b36ed.jpg
Size: 51.1 KB](https://rennlist.com/forums/attachments/panamera/1236084d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-before1_zpsb03b36ed.jpg)
In just 3 minutes the temperature rose to 92 degrees
![Name: BEFORE2_zps0ac435f8.jpg
Size: 80.4 KB](https://rennlist.com/forums/attachments/panamera/1236085d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-before2_zps0ac435f8.jpg)
Close to 7 minutes, the air temperature rises to 105 degrees
![Name: BEFORE3_zps2685b755.jpg
Size: 75.9 KB](https://rennlist.com/forums/attachments/panamera/1236086d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-before3_zps2685b755.jpg)
At the 15 minute marker, temperature is at an unbearable 123 degrees
![Name: BEFORE4_zpsc4381e0c.jpg
Size: 76.3 KB](https://rennlist.com/forums/attachments/panamera/1236087d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-before4_zpsc4381e0c.jpg)
26 Minutes - Temperature now reads 136 degrees
![Name: BEFORE5_zpsd74508c8.jpg
Size: 74.2 KB](https://rennlist.com/forums/attachments/panamera/1236088d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-before5_zpsd74508c8.jpg)
At the end of the 30 minute test, it is a scalding 140 degrees, which is the reason why leaving children in a vehicle can be a fatal mistake.
![Name: BEFORE6_zps4c8f8001.jpg
Size: 117.9 KB](https://rennlist.com/forums/attachments/panamera/1236089d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-before6_zps4c8f8001.jpg)
Test Vehicle 2 with Spectra PhotoSync 45 installed to the side and rear hatch.
Test starts at 85 degrees
![Name: SPH45_zps055c89b8.jpg
Size: 89.0 KB](https://rennlist.com/forums/attachments/panamera/1236090d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-sph45_zps055c89b8.jpg)
At the 15 minute marker, it is 96 degrees compared to Vehicle 1 at 123 degrees.
![Name: SPH45_2_zps4cb56bee.jpg
Size: 87.0 KB](https://rennlist.com/forums/attachments/panamera/1236091d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-sph45_2_zps4cb56bee.jpg)
At the completion of the test at 31 Minutes, the Tesla Model S with Sepctra PhotoSync is at 104 degrees compared to 140 degrees in the other Tesla. This is a 36 degree differential!
![Name: SPH45_3_zps5070b8cd.jpg
Size: 63.4 KB](https://rennlist.com/forums/attachments/panamera/1236092d1501791993-hot-out-there-prestige-photosync-nano-window-film-is-the-solution-sph45_3_zps5070b8cd.jpg)
IF YOU ARE SEEKING AN INSTALLER OF SPECTRA PHOTOSYNC AND NOT LOCATED IN NORTHERN CALIFORNIA, CONTACT THE MANUFACTURER, PRESTIGE FILM TECHNOLOGIES, TO SEE WHO THEY HAVE IN YOUR AREA:
408-657-3880 OR vtran@prestige-films.com
Today we took a quick surface temperature reading on a 2014 VW Touareg we just received. The car was sitting outside for 15 minutes before we brought the vehicle inside to our facility. But before we did, we found these astounding numbers:
Front driver seat - 156 degrees F
Front driver side dash - 163 degrees F
This is the reason dashboards and leather seats tend to crack over time. Daily exposure to the sun's UV and infrared rays can wear down the interior significantly in a short amount of time. Product quality and performance is why we choose to use Spectra PhotoSync Nano Tint by Prestige Film Technologies.
Spectra PhotoSync reduces total solar energy by up to 79% and block out up to 98.5% of IR and 99.5% of UV. We have used most of the high-end tint out there and there's nothing on the market, in our opinion, that can stack against this product
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=374209&dateline=1400020370)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=374210&dateline=1400020370)
![](http://i556.photobucket.com/albums/ss4/premiermobilegroup/Photosync/VW%20Touareg/IMG_0300_zpsa36fa4d5.jpg)
Every window film comes with the performance aspect, but not all of them are created equal. Some use metals, ceramics, etc. Most importantly for cars today, get some type of film that does not have any metals in them. Here is a very simple test we created to show that PhotoSync performs extremely well without having any metals in them:
