AC Thermostat Gremlins
Anybody have a similar experience?
I've got a 2010 P4S.
I was cruising down the highway during the recent heat wave in 108 degrees with the air conditioner set to 63 degrees. All it once the system stopped cooling. No unusual sounds, no warning lights. After stopping at the supermarket, I restarted the engine and everything worked fine. No recurrences.
I took it to the dealer, they ran diagnostics, and found nothing.
The dealer said there was no TSB on this issue for my car. They said it was an automatic safety function that likely happened when the unit was operating under overheated conditions. Since I was travelling fast on a hot day in hilly winding roads, it makes sense. I'll check on the drainage issue if the problem arises again. It's back in the shop now for rear spoiler malfunction. It's not the most trouble-free Porsche I've owned for sure.
