4s burning oil
4s burning oil
weve had our 4s for 2 yrs and 15000 miles of mostly suburban driving. everything works well except excessive oil use. about 6 qts/yr. no stains in driveway, no smoke from tailpipes, and engine compartment is clean so i assume no leak either. ive read about this issue being normal but this seems excessive. any ideas? thanks
No they don't.
I'm at 6800 miles on my 2012 S, and I have yet to add any oil. The display still shows one bar before I need to add oil. I keep a quart in the car to add when the day comes, but I have no problem with the oil consumption in my car.
My 4S is currently burning at the rate of 3,500 miles per quart after 15,000 miles. Not in the league with my wife's BMW at a quart every 5,000 miles (with 47,000 miles) but certainly not excessive. At a quart per 600 miles, I would be concerned about coking up the cats probably when the warranty runs out after 80,000 miles which is 130+ quarts down the road.
Wow. Just seems like a lot esp since my old 07 gt3 that experienced same condition plus at least 6 track days/yr didnt require any oil between changes
It is a LOT
It is quite a large amount of oil. However this thread shows how little folks read their owners manual.
If your going to buy a very expensive car, read about how to operate and maintain the vehicle.
Harsh, but true. As Joe Friday said on Dragnet; "Just the facts Son, Just The Facts"
Cheers, JohnnyB
Cheers, JohnnyB
thanks for all the advice. if youll re read my op, you will see how i said "ive read about this issue being normal". i read it in the owners manual but its still shocking so i wanted confirmation here
The best way to break an engine in is to do 2,000 miles in one shot. You want to do varied driving - speeds, rpm, gears, without exceeding around 4,500 and half-throttle. From your mileage, it sounds like you probably took 3-4 months to hit break-in mileage, and that would be lots of cold starts where the engine was pretty much drained of oil. The engine will see more wear in the first couple minutes of a cold start than many hours of running after that. Infrequent short trips is the worst way to break in an engine, and a tough way to run it if you want to minimize oil consumption.
I'm not criticizing the way you drive, since you're not doing anything wrong, and maybe you broke it in driving the back roads from New York to Florida. But Porsches and BMW M engines oil consumption will vary a lot depending on break-in and driving habits.
mowhawk (10-21-2019)
