MORR MS10-Rs - Contoured Step lip - 21x11" - 25 lbs - a must see!
A few months ago we introduced MORR's new MultiForged series with the MS8 and MS10. They are currently working on photoshoots to officially launch the MultiForged series, today I'd like to take your time to feast on these new MS10-Rs, a contoured step lip design for a Panamera we just finished in hand brushed centers and polished lips. The 21x11" wheel weights in at a staggering 25 lbs!
A full photoshoot of the wheels mounted is coming soon
Wheel info:
http://www.campionishop.com/products...nd=5012&clev=0
MORR MultiForged is MORR answer to a far behind 3pc market that has remained stagnant in many aspects of wheel manufacturing technologies. The MORR MultiForged collection is as different as it can get when it comes to 3pc wheels. Assembly of a MultiForged wheel takes 3 hours per wheel, the back-pad is engineered with torque-assisted mounting and Anti-Water rain grooves for water retention prevention, to virtually eliminate any and all possible vibration issues that can occur. Furthermore, all MultiForged wheels receive a low curing powder corrosion protection coat on both the outside and inside barrels for additional corrosion resistance and cosmetic appearance. Lastly, because of the use of proprietary assembly components and techniques we are able to torque our assembly bolts close to 2.5 times more than the traditional multi-piece wheel providing a structure that is more resistance to loads. Our fasteners are are stronger, lighter, and much more resistant to corrosion when compared to the zinc fasteners most companies use. Titanium Fasteners are also available.
MORR uses a proprietary silicone sealant that was co-developed with 3M to seal the inner and outer parts. This sealant is specifically designed for modular wheels making it preferable for heat resistance, temperature changes, corrosion, humidity and more. And every wheel is assembled and torqued by hand for utmost care. Aside from all of these features, the MORR MultiForged collection includes standard features that are only offered as “optional” features by most. These standard features include but are not limited to:
Race-Prep Precision Machining
BackPad Precision Pocketing
Side-Spoke Precision Pocketing
Powdercoated Inner & Outer Barrels
All of this precise additional machining adds significant manufacturing cost, but dramatically reduces the weight of the wheel, all while maintaining all of our strength and structural integrity criteria when subjected to FEA Analysis, DOT SAE-J2530 testing, and VIA/JWL Testing and registration.
And now to the eye candy
Wheel info:
